clayguthrie29
hello all,
I'm working on a Acer Aspire 3680 laptop with a power issue. Plug it in, no lights, no power...nothing. Checked the charger and it tested fine ( 120 vac in, 42 vac out ). I've attempted to power on with and without battery. I've pretty much got it ruled down to a bad power board, but i wanted to double check my work.
Would i be accurate to assume that if the power board was outputting power, i would at least get a light?
Is the power light bypassing the motherboard or does it pass through it? And if it passes through it, it is possible i could have a bad motherboard. ( I would assume for troubleshooting purposes that the charge lights are bypassing the board. )
I'm pretty confident in my ruling, but would like some input from you guys. thanks in advance.
