I'm taking a look at on old Gateway computer for a friend. Every time it boots the "Add new Hardware" wizard keeps finding the following devices:
PCI Communications Device
PCI Multimedia Audio Device
Unknown Device
Each of those 3 appear in the Device Manager with a big yellow question mark with a small exclamation mark on top of it.
and the video is lousy. On the Settings tab of Display properties I'm stuck with either 2 or 16 colors and a screen area of 640 x 480 and I can't change it.
I opened the case up and removed the dial up adapter so the PCI Communication Device is no longer found when Windows boots. I installed a Realtek NIC and windows saw and set it up properly. There are no other cards in any of the slots.
I'd like to find the proper BIOS to install and go from there. I've tried this one: WL81020A.15A.0007.P06 from Gateway support (silly thing won't let me post a link yet).
but still have the same problems. A note regarding that BIOS says "...the update process fails if you use a floppy disk formatted in Microsoft Windows 2000, Windows NT, or Windows XP.....". I used a Windows 98 startup disk I created using the OS on the computer But I wonder if the flash was successful or not - when I reboot & hit F1 to get into the BIOS the info is the same as it ws before I tried to Flash the BIOS (then again it should be if I'm using the correct BIOS, right?).
Computer Profile Summary
Computer Name: X9a4q6
Profile Date: Friday, March 28, 2008 10:45:02 AM
Advisor Version: 7.2x
Operating System System Model
Windows 98 SE(build 4.10.2222) Gateway BRYANT 4000678
Enclosure Type: Desktop
Processor Main Circuit Board
933 megahertz Intel Pentium III Board: Intel Corporation WL810EAAA27218-206
32 kilobyte primary memory cache Serial Number: IUW210602715
256 kilobyte secondary memory cache Bus Clock: 133 megahertz
BIOS: Intel Corp. WL81020A.15A.0007.P06.0010031249 10/03/2000
Drives Memory Modules
2.15 Gigabytes Usable Hard Drive Capacity 64 Megabytes Installed Memory
1.56 Gigbytes Hard Drive Free Space
Slot 'DIMM1' has 63 MB
IDE-CD R/RW 8x4x32 [CD-ROM drive] Local Drive Volumes
MITSUMI CD-ROM FX4831T!A c
FAT on drive 0) 2.15 GB 1.56 GB free
Generic floppy disk drive (3.5") Network Drives
None detected
Generic IDE hard disk drive (2.15 GB) -- drive 0, No SMART Driver
Users (mouse over user name for details) Printers
No details available None detected
Controllers Display
Standard Floppy Disk Controller Standard PCI Graphics Adapter (VGA)
Intel 82801AA Bus Master IDE Controller [Display adapter]
Primary IDE controller (dual fifo) Gateway LE500 [Monitor](13.5"vis,s/n LIC04556494, November 2000)
Secondary IDE controller (dual fifo)
Bus Adapters Multimedia
Intel 82801AA USB Universal Host Controller Gameport Joystick (no joystick connected)
MPU-401 Compatible
Communications Other Devices
Realtek RTL8029(AS) PCI Ethernet NIC Standard 101/102-Key or Microsoft Natural Keyboard
primary Auto IP Address: 192.168.1.101 / 24 Microsoft PS/2 Port Mouse
Gateway: 192.168.1.1 USB Root Hub
Dhcp Server: 192.168.1.1
Physical Address: 00:4F:49:0C:A4:BF
Unknown Device
None detected
Controllers Display
MPU-401 Compatible
