Adding perl script to hosting
4ycr
West Lothian, Scotland
Not sure if this is the correct place but
I am having trouble installing a perl script. I have upload it to the correct directory but when I search I get the following error
There was a problem fetching the list of available modules.
Even when I say to install it by name I get the following error
Testing connection speed...(using fast method)...Done
Ping:3 (ticks) Testing connection speed to cpan.mirror.clemson.edu using pureperl...(15025.00 bytes/s)...Done
Ping:3 (ticks) Testing connection speed to cpan.dagolden.com using pureperl...(10940.00 bytes/s)...Done
Ping:3 (ticks) Testing connection speed to mirror.sit.wisc.edu using pureperl...(13520.00 bytes/s)...Done
Three usable mirrors located
Mirror Check passed for cpan.mirror.clemson.edu (/index.html)
Bad module name (ultravnc_repeater.pl) detected, skipping it.
My host is using Cpanel Accelerated 2. Do I need a cgi flder in my public html folder? I say I have uploaded it to the correct place, well it's the place that is displayed on the perl cpanel page and it is the perl folder.
Any help is appreciated
Uploading a script or a module?
You whole have a cgi-bin folder in root, along with public_html, and will need to CHMOD 0755
Sent from my GT-P1000 using Tapatalk
It was using a script but I am not sure if I can do this now as it only says module.
Do you allow scripts to be installed on your hosting puzz1ed1? I might convert over as I will soon need the extra space
Of course :) have just doubled the space on all base packages too and enabled automated ordering/setup. Haven't updated the ACRBO offer great though but will post a discount code later.
I'm away atm with limited access, otherwise would offer to help with the install. Hope you get it sorted!
Steve
Steven,
TN20 will give 20% off all hosting packages - happy for anyone here to use it if it helps your business :)
