Digital Sage
- Merimbula, NSW, Australia
Next week I have a job where I need to run some Ethernet from one house at front of big block, to another house at the rear. The two houses are about 80 meters apart. There's another house in the middle... The block is on a slight incline so rear house easily overlooks middle and front house.
Basically the whole reason "why" is that only the front house can receive internet (end of exchange) : the rear house doesn't qualify. The block is owned by the same family, so no issues with that.
Guy I'm doing it for, he's bringing conduit and we'll be burying the cable, under the rear fence line.... Have to get through a couple of brick walls.
I'll be putting a high powered wifi router at the other end to service the rear house and the house in between. Will be connected to the front house right into ADSL modem router. So front house internet connection will feed wireless router at rear house via Ethernet run.
Having a hard time finding outdoor rated Ethernet!
Not sure if I should go with cat 5, 5e, 6 or 6e.
Any suggestions welcome. Haven't done anything like this before!
