Appletax
- Northern Michigan
Solution: the connector is USB Type-E. The mobo does not have a port for this newer tech. It can share the front USB 3.2 Gen 1’s USB 3.0 header by splitting it, and then putting an adapter on one of the two headers. Speed would be half the 10 gig potential of the USB-C add-on. Not worth the trouble given that there’s USB-C ports in the rear.
Example of one on a Z790 Asus mobo that goes up to 20 gigs:
Client's gaming PC case has a USB-C port spot that is empty. They want the USB-C add-on from Fractal installed. Problem is that I am unfamiliar with the mobo connector on the cable - never seen this connector type before. I have no idea how it could be inserted into the mobo. Both the mobo and the add-on's manuals are of no help. What to do?
Case: Fractal Pop Series XL Air [Model: FD-C-POR1X-06]
Mobo manual: https://dlcdnets.asus.com/pub/ASUS/mb/SocketAM4/ROG_STRIX_B550-F_GAMING_WIFI_II/E18592_ROG_STRIX_B550-F_GAMING_WI-FI_II_UM_WEB.pdf?model=ROG STRIX B550-F GAMING WIFI II
USB-C 10Gbps Cable – Model D
Looks like a cross between a SATA power cable connector and a DisplayPort connector.
