I have one computer that has something messed up (Windows 10, bit surprise) where when I run the Java installer it opens dozens of IE windows, which immediately close. It happens with the offline or online installers. Originally I had to hit an "Allow" or "Deny" button for each one (to display the content), but I checked the box not to ask again.
The windows are all blank and all go away immediately. Eventually the installer comes up with a totally blank window. As near as I can figure what it going on the installer for Java uses some IE functions to display the setup screen and for some reason it is trying to open each component in a separate IE window instead of showing it on the installer. I have no idea what would cause this, though.
What I've done:
I've run a Tweaking.com Windows Repair with no change (because it does the SFC and DISM commands). The computer originally came in because it gets a fake tech support screen multiple times a week, although the customer admitted that may have something to do with the sites he frequents. It did have a bunch of "Proxy" lists in HijackThis (yes, I'm still using it), most of which couldn't be removed due to permissions. The owner was either System or Trusted Installer and everyone else, including Administrator, had only Read access. I took ownership of each registry entry one by one to delete them. I've also run JRT, ADWCleaner and Norton Power Eraser. Not much in the first two, nothing in the last one.
What I've done:
