If it never connects to the Internet, it doesn't require protection.
So I'm looking for another.
Antivirus without OS updates are almost useless. How can you defend your computer if Windows itself has security holes...Deploying Windows updates like this is often creates issues when an update needs previous updates to have been installed.
Stuxnet heheA computer that is never online should be fine without all of the updates. I'm only worried about viruses from USB sticks.
Whats the computer used for, Can you Disable the USB ports?A computer that is never online should be fine without all of the updates. I'm only worried about viruses from USB sticks.
It's mainly a fancy word processor and without a connection there's no way to get info in or out.Whats the computer used for, Can you Disable the USB
There are still viruses that mess up the system. Just got finished with the Winddowsupdate one. It leaves the computer alone but infects all USB sticks that are connected.Most modern and current infections want either to harvest and remotely send sensitive data or turn the system into a node on a network so in effect few if any virus pose a real danger to the system in the grand scheme too. A true offline system even if infected will pose little to no risk from most virus as the days of virus to take down a system are gone it is the virus to use your system and/or data..
Never said they were gone and that still does much that same as what I described just using an old fashioned method of transmission & delivery and likely for any system not offline I wouldn't be surprised to see network activity from it. I would also look at this system in a whole picture view. Where will outside resources come from? If the sources are known and within the control of the same operators then focusing on managing the protection there provides effectively the same protection to this machine. If this is not the case perhaps a managed system that serves as a sanitation point prior to being put on the destination system it would be simpler to implement and maintain but require proper procedure from the users which I know is a big ask but would put the responsibility back on them over you.There are still viruses that mess up the system. Just got finished with the Winddowsupdate one. It leaves the computer alone but infects all USB sticks that are connected.
I agree with the USB comment. Even if it never connects to the internet, does it still connect to other network devices? If so, it can be infected that way as well. The Windows Defender that comes on every windows computer might be enough, but I would still look at something that would protect and monitor the external devices that are plugged in.Heaven forbid, we're almost in agreement. The exception could be if there exists a "sneaker net" where new material is constantly being introduced via thumb drive or SD card that could be infected.
I'd say you don't even need OS updates, really, if what you've got does what you need if there is no contact with cyberspace.
