untoldtech
I'm using an older application that a customer requested. It runs fine in windows 10. I've found that if I'm using dual monitors with this application it will *not* move to the secondary monitor and will only stay on the primary monitor. I've done all sorts of things like holding shift and dragging etc and it doesn't work. Only this application and nothing else has this issue so it's specific to this application. Anyone ever seen this before and know a way to force an application to be on the secondary monitor instead of the primary? I'm wondering if this is something to do with the .net version or something that it uses.
