Captain Spaulding
- Chichester, West Sussex, UK
Hi,
Just wanted a 2nd opinion before I tell the customer they have a bad MB:
Symptoms:
Random BSOD's (normally hal.dll ntoskrnl.exe)
Sometimes will power on for 3 secs then switch off
Sometimes the screen freezes completely, only thing possible is to hold the power button
Memtest+ different versions immediately shows errors every time with both RAM sticks in, with only one or the other in, tried both slots, even tried a good RAM stick same thing, a few times it rebooted itself during memtest and also gave the error (unexpected interrupt halting) and froze.
Tried:
Disconnecting everything except PSU, MB, Memory, CPU
Swapped PSU for a new one
Swapped the CPU for a known working one and re-did the paste
Checked caps but they all look good
I suspect its either bad ram slots or MB, can't think of any other tests I can run. The customer did tell me the hovered out the case so maybe they screwed the motherboard when they did it.
I've never seen memtest fail with good RAM before but I guess this points to a motherboard issue.
Symptoms:
Tried:
