thecomputerguy
I have a client I setup a shared mailbox so they could temporary receive mail at jobs@ while they look to hire someone.
Logged into O365 Exchange Admin Center > Mailbox's > Shared Mailbox's
Created the new shared mailbox and gave the user full access to the mailbox, send & receive.
Opened up Outlook after a few hours and added the mailbox in "Open additional Mailbox's" in account setup.
The mailbox shows up fine ... Click new mail > From (Dropdown) > Other Email Address
I select the shared mailbox email address and send the mail and it works fine.
Next time you goto send mail jobs@ is already there in the dropdown ... you select it, then send the email and I get this bounceback. Basically the email always goes out the first time no problem, then once you select the shared mailbox from the dropdown (From field) it will no longer work until you remove the shared mailbox from the dropdown (hit the X), then manually go and re-add it. Then it sends one, and bouncesback all over again. Help?
Your message did not reach some or all of the intended recipients.
Subject: Receptionist
Sent: 8/31/2017 3:49 PM
The following recipient(s) cannot be reached:
'xxx@ymail.com' on 8/31/2017 3:49 PM
This message could not be sent. Try sending the message again later, or contact your network administrator. You do not have the permission to send the message on behalf of the specified user. Error is [0x80070005-0x0004dc-0x000524].
