Appletax
- Northern Michigan
Solution: @inbargains can fix it
HP Spectre x360 Convertible - Model 15-df0023dx - Serial # 5CD9268SY9
Screen is busted and display assembly is twisted. Replacing the entire assembly.
Super carefully removed the WiFi chip's antenna cables. The main port broke. Super, super fragile.
Chip is soldered. Have to replace the entire motherboard to fix this. There's no slots to install a new one.
Sooooo stupid!!!! The solder is razor thin!
Can someone repair it with soldering?
I am going to suggest a nano-sized USB WiFi adapter. It is not my fault that his expensive machine is a POS HP
Like this one
Should I even bother to attach the new display's WiFi antenna cable to the intact Aux port?
What would you do?
Like this one
What would you do?
