frase
- Melbourne, Australia
I had a client with a laptop where the hinge had come away from the lock nut on the laptop base. The laptop when it opened would raise the edge of the laptop - rendering it useless.
This is always annoying [and common] as one cannot glue the lock nuts back in place. So rather than the client purchase an entire new back for the laptop, I came up with a simple solution.
I dissembled the laptop to have access to the hinge bracket.
Using a drill bit not much bigger than 2mm, Drilled two holes through each bracket inside the laptop - so it went through the laptop base.
Using two 3mm bolts I screwed these through the base and through the hinge brackets, and tightened each bolt in place with needle nose pliers.
Voila - easy fix! [I did advise the client beforehand of course]. Not the best looking solutions but client was very happy with result. I couldn't find any flat ended bolts in my area unfortunately at the time.
Images below -
Images below -
