Can't find DC Jack replacement...
DanF
EU
I have a Sony VAIO PCG-8141M on the bench with DC jack issues. Problem is, I can only find the jack at one place, that is http://www.nbjack.com/
The problem is, there doesn't seem to be any contact information. Do you know anything about them? Can you suggest maybe someone else? I'm not in the US, if that makes a difference.
That's what I'm looking for. Thanks Andy! :) Are you registered with them as a business? It even lists Malta in their shipping page (not something we see everyday haha)
Express hipping is somewhat expensive, but I'm sure I can do with normal shipping, considering this will reflect in a cheaper bill to the client.
One other thing to consider it that you may be searching by the wrong model number. If you don't go by the actual part number on the part (which you should) then you need to go by the model number that is usually located at the bottom right corner of the screen. If the model number is not there the find the other model number that does not start with PCG.
Absolutely correct. You may be looking for VGN-AW21M or similar. @DanF - Also have a look at the list of laptops it is compatible with on that page http://uk.eetgroup.com/i/196634011-Sony-DC-Cable-In
You may be able to search other sites or Ebay by a more common model number.
