Go-To Gordon
- Asheville, NC
I have a client that I will be running a few new data drops for, terminating wall plates etc. I have no issues with this.
They also have one phone drop that they need to extend. In the network closet they have an old 66 block with all the phone wiring (cat5e). One drop (connected to the 66 block) goes under ground to a building about 100 feet away. They had a phone there and it worked just fine. They now built an office in the back of the building and want to move the phone there. The cat 5 has been cut and the phone removed so I need to splice into that to run a new drop in building 2.
My question is should I just use cat 5 junction boxes like you would for data? I'm not sure how it's wired to the 66 block so wasn't sure how to handle the splice. If I use a junction box I then just wire the 2 blues on the phone jack end?
If it's anything beyond this I have a phone guy I can send them to. Just thought if it's easy enough I could take care of it while I'm there doing the data stuff.
