Tech bud
- Oshkosh, WI
This is an HP Pavilion a6333w, its an old computer that my friend was going to get rid of and get something new because it wasn't working. I took it off his hands because I wanted to fix that computer and turn it into a server for my place. Things I tried:
Any suggestions on what I should try next? I'm thinking I want to try a BIOS update or flash and see if it will run stable after that.
- At first the computer would not boot, I got all his documents off the drive and gave it to him for his new computer by using a boot cd.
- Then I reformatted the drive and reinstalled the old OEM OS (windows vista 32bit). The computer would start up. but I would get blue screens, so I ran seatools, the hard drive failed the test.
- I put in a known working drive, still would get blue screens, then I reinstalled the old hard drive, ran Western Digitals hard drive test, because that is the drives manufacturer. It tested fine.
I ran memtest on one stick, it tested fine, I ran the one tested good stick on all dim slots, all dim slots are ok.
Proceeded to insert the other sticks one at a time and test, one stick tested fine while the others will not even let the computer boot up. But the catch is with the two sticks that were tested fine, if in the dual channel slots together, the computer will freeze at the BIOS screen.
I also tested the PS, it is fine.
