Customer has 2 iMacs, a dead one and a working one. The task at hand is to transfer the system from the dead iMac to the working iMac. My plan was to boot the good iMac using the drive from the dead iMac mounted in a USB attach docking station. Unfortunately, the HD shows up as "unformatted" when looking at it in the good iMac.
Made a back up of the HD using ddrescue on my Linux machine. Finished with 100% copied (i.e. no bad sectors - so this is not a hardware issue).
Booted the good iMac and ran Disk Utility and tried First Aid on the bad HD. It failed. Looking at the disk util log file, I see the following lines:
Performing fsck_cs -n -x --lv --uuid 4945FCF1-C98F-4F25-BD6B-5A46C24FFDBA
Checking volume
disk2s2: Scan for Volume Headers
disk2s2: Scan for Disk Labels
Logical Volume Group 4945FCF1-C98F-4F25-BD6B-5A46C24FFDBA spans 2 devices
Incomplete or inconsistent CoreStorage Physical Volume set
Storage system check exit code is 1.
I'm no expert on macOS file systems, but this seems to imply there should be a 2nd drive somewhere. Can this be an external USB drive? Other explanations? (full disk util log attached to this post).
Mahalo,
Harry Z
Checking volume
Mahalo,
Harry Z
