brandonkick
So I have a use case where I need to connect multiple (in this case, expanding to 3 monitors from the existing 2) displays to a pre built Dell desktop.
I know there are all sorts of weird combinations of what works and what doesn't work in terms of using integrated display outputs with add on GPU cards. This client is over an hour away, prefers me to do the work in house, and I don't want to make more than one trip.
I'm thinking instead of trying to hope and pray that this Inspiron 3880 will support using both the integrated display outputs AND some from an add in GPU.... that I can find a GPU that will support at least 3 (hopefully 4) displays all from that one card?
I would be fine doing the 2+2 (2 integrated, 2 GPU) option if anyone can confirm for me that this will work with that machine. I've done a fair bit of googling, nothing definitive. Otherwise, can anyone recommend a good (smaller / lower power) GPU that would support 4 displays (HDMI should be fine) on one card? Right now they are using a combination of DisplayPort and HDMI. This new (what would be the 3rd monitor) is HDMI. So two HDMI, one DisplayPort (though I think it supports HDMI too...).
Thank you in advance!
