Upgrading the RAM is always the best way to increase the performance of just about any computer, including a lot of older models that are still in use today. There are, of course, exceptions, but this Dell Optiplex GX240, with two slots and a max capacity of 1GB, would definitely benefit, as long as the owner is not drastically changing the way he intends to continue using it. The CPU is usually the “limiting” factor for things like videos or, now, the increasingly popular watching of streaming TV, but this pc has a Pentium IV with a range of 1.5GHz - 2.0GHz (have to check what his has), which should be more than adequate for everyday computing. The 128MB of RAM that this machine shipped with is not.
Iptech’s assessment is right-on and this RAM is unbuffered, but to take it a bit further, it can also be ECC (error-checking and correction) or non-ECC - check out Wikipedia for an explanation; while this machine can handle either form, all the modules must be of the same type, and I suspect that this may be the cause of the beeping sounds encountered in this case. The ECC is indeed the more expensive, yet neither is difficult to find. Most techs use crucial.com and the memory scanner available to determine the type, amount, and max capacity of the RAM for any given computer (if it has an internet connection), but I recently discovered a better utility from oempcworld.com - it’s more thorough, easier to understand (and print!), plus the recommendations are more accurate and detailed. A quick search on the site for this Dell pointed me to a whole page of RAM options, notably a 512MB, non-ECC, PC-133 SDRAM module for $28. What’s even better is that shipping is free if you choose the first class mail option - they’ll tell you how long delivery might take, but I’ve always (5X so far) received mine within two days!
If I were doing this for a family friend looking to save money, I’d max it out with 2-512MB non-ECC sticks for $56, making all the concern about compatibility moot, then add an AV utility and good firewall (free ones, of course!) that would barely hinder a now much improved pc…
PS. XP will respond great, and Win 2000 or most Linux distros will fly, but Win ME must be replaced!
