I recently set up a WSE 2016 Server for my client. He requires himself and his two colleagues to use a vpn connection to a server, so that they can run petroleum engineering software on their laptops remotely. Although the software is installed locally on their laptops, it needs to authenticate against the licensing software on the server, so that they can actually use the programmes on their laptops. So far, so good.
My clients' laptops use user profiles which are 'domain' (not local/workgroup) profiles which were at some point connected to a server which has now been decommissioned. So, all their user experiences is stored on the existing domain profiles.
In order to connect these laptops to a new domain (WSE 2016), it is necessary to 'disconnect' the devices from the old domain (system properties - computer name - change - and select 'Workgroup'). This removes the domain profile account but it does seem to keep all the various user folders, such as Desktop, Documents etc on the C:\Users root. The downside is that it is not possible then to migrate the old domain user profile to the new domain profile, as the old domain profile does not show as an existing account in 'User Accounts'. So, everything has to be re-created manually - Outlook, One Drive, Bookmarks etc.
Having joined my client's laptop to the new domain, it broke the 'old' domain user profile, which he normally used for all his work. So, he had to recreate his new profile, which took him some time to do, days not hours. I know there are tools to migrate user profiles, domain or workgroup, but he is concerned that joining the other two laptops will cause similar problems, backup or no backup. So, I would rather not go down this route, as he is uncomfortable with it.
So, thinking of ways around this conundrum, installing Server 2016 in Workgroup mode on the Dell T140 Power Edge WSE 2016 Server, is probably more trouble than its worth. And, even if this route is chosen, it will probably still break the domain profile which the laptops use.
Another possibility is to set up virtual machines (VirtualBox) or perhaps use the built in functionality of Windows 10 Pro (Hyper-V) to create new instances of W10 Pro on the laptops and join these instances to the domain (WSE 2016). Presumably this would not tamper, alter, break or in any any way interfere with the existing domain profile on the host machine? Also, is this configuration supported by Microsoft - a virtual W10 Pro machine joined to a WSE 2016 Server?
Any thoughts would be greatly appreciated, as I am running out of ideas, and I would like to help them move forward.
