rustynails87
- Cape Cod
Hello all,
I have an HP envy laptop that I'm having an issue with. My client has two of the exact same laptops - one of the power supplies died and they had a spare one laying around so they decided to use that one. This power supply was underpowered and when plugging it in it would not charge the battery. If the battery died it wouldn't power on so they were occasionally swapping batteries back and fourth with the other laptop that was charging and working fine. They asked me to look at the laptop. First of all the laptop had a bad jack and I replaced it. After replacing it the underpowered power supply would no longer be detedted by the laptop (the light did come on however). I figured I'd leave it plugged in for a while to see what happens. Now the battery is dead and the laptop wont turn on at all (no battery indication light either). I have another universal power supply here (the one with the interchangeable tips) and tried using that but still no charge indication light or anything... I tried swapping back the other power jack and nothing... I'm at a standstill. Any ideas as to what could be wrong? Motherboard? Battery is fine and power supply is fine as well (tested on other machines).
Thanks
Thanks
