HCHTech
- Pittsburgh, PA - USA
This is my week for intractable problems, it seems. I've got a small office client - local utility. They have a year old Server 2019 server (Single App Server VM - no DC) and 4 workstations (one is 3 yrs old, the others are 2 years old. All Ryzen 5's, 16GB RAM & 250GB SSDs. They all have Office 2019. For some reason about a month ago Excel started opening files on their server share slowly. These are not big, complicated files - the one I've been using to test is a simple calendar spreadsheet - it's 120KB with no extensive calculations or external links. If I open it from the network share, I get the little "downloading" progress bar on the bottom of the Excel window that stays at 0% and it takes 20 to 25 seconds to open. Doesn't matter if Excel is open and I use File/Open, or if I just double-click on the file in File Explorer. If I copy that same file to the desktop of the workstation, it opens instantly.
The rest of the Office applications don't exhibit this problem. Word files and Powerpoint files open on the network share normally. Copying large files back and forth over the network works normally and is fast. All of the workstations exhibit this behavior with Excel to some degree. The delay is longer on some than others, but there is a delay on all for Excel files on the server.
Things I've checked and done (in addition to wearing out Google)
- Checked that Office is up-to-date on all computers - it is
- All workstations are at 20H2
- Checked for errors in the server logs - found nothing suspicious
- Ran Office Repair - no effect
- Toggled SMB1 on the server on and then back off again
- Workstations are not Dells and don't have realtek drivers (this is a known bug)
- Toggled SMB 1 on the workstations on and then back off again
- Added the server shared drive to the trusted locations in Excel - both UNC and mapped drive
- Disconnected shared drive and remapped it. Tried mapping via IP vs. UNC.
- Disabled hardware acceleration in Excel (this actually helped shave a couple of seconds off the loading time)
- Checked for an updated NIC driver - there was one, but no effect on the symptom.
- Checked CPU, memory and disk load during the opening process - no spikes. Hardware not working hard at all.
- Checked that no one had managed to enable Cortana - that's a common cause of this behavior.
- Tried opening Excel in safe mode - no difference in behavior - that means it isn't an add-in
- Check the server load - it's not even breaking a sweat. It runs their customer database and holds a small file share - that's it. Lots of processor, memory and storage to spare.
- I have NOT tried taking a workstation back to 2004, that's not a long-term solution, even if it did fix the issue.
