Aloha folks. I'm back again with another "is this drive failing, or not?" question.
I'm testing a new-to-me tool called Malwarebytes Toolset (it is yet another diagnostic tool aimed at technicians and has the various Malwarebytes tools built in along with capability to add your own tools). When I ran the "Scan" option that looks for things that might be wrong, it found 80 event log entries indicating possible problems with the hard drive. The two different entries that were found look like this:
Level Date and Time Source Event ID Task Category
Warning 4/27/2017 2:29:29 PM Microsoft-Windows-Ntfs 147 None "An IO took more than 30000 ms to complete:
Process Id: 4
Process name: System
File name: 000A0000000349CA
File offset: 4526080
IO Type: Write: Paging, NonCached, Sync
IO Size: 684032 bytes
4 cluster(s) starting at cluster 520397
Latency: 40914 ms
Volume Id: {506A37EB-5B09-4228-8FE9-22062359611A}
Volume name: C:
Is boot volume: true
Warning 4/27/2017 2:38:05 PM Microsoft-Windows-Ntfs 149 None "In the past 3600 seconds we had IO failures.
This may indicate a failing disk.
High latency IO count: 1
Failed writes: 0
Failed reads: 0
Bad clusters relocated: 0
Volume name: C:
After seeing this, I created a full disk image using ddrescue.
- ddrescue copied all sectors with no errors.
- SMART shows no problems (and yes, I know that SMART is not a reliable indicator of disk problems).
- This is a WD drive, so I ran Data Lifeguard Diagnostics both short and long tests and both passed
So, is this drive starting to fail and only Windows is able to detect this? Or can I ignore these event log entries?
Mahalo for sharing your knowledge!
Harry Z.
Process Id: 4
Latency: 40914 ms
Volume name: C:
Failed writes: 0
Failed reads: 0
Volume name: C:
Harry Z.
