britechguy
- Staunton, VA
I know that nothing is entirely "foolproof," but some things come closer than others.
I just received a Silicon Power drive on to which I want to clone the OS drive which it will be replacing. They supply NTI Echo v5, but I cannot get it to work. It fails at the "creating partition table" stage for the target drive. I tried this with the target drive entirely uninitialized, initialized but with no volume created, and then after creating a volume using the Windows 11 Initialize Disc function that's now a part of Settings.
In the past, Macrium has been recommended, and I can and will use that if need be, but since the free version of Macrium is not long for this world, I though I'd ask what other options might be recommended.
I don't often have a need to clone discs, and for the most part whatever the drive manufacturer gives me to do that generally works, but there are always the contrary instances like this one.
I also know I have the option to take a full system image backup and then restore that image on to the new SSD, but I suspect there will be issues with that since the new SSD is 512 GB while the old HDD is 750 GB, though not even 100 GB is taken up as actually used space.
