tf76
- South Australia
Free until May 5th. Grab serial key from page.
http://www.winpdfeditor.com/giveaway.html
WinPDFEditor is a Windows PDF editing software product that lets you modify and edit PDF documents like adding text, insert images, removing unwanted content, drawing lines and rotating PDF pages.
If you write text on the PDF, you can change the text font, size, color and move it to anywhere you want on the page. After inserting an image into PDF, you can resize the image and move it also. If you find some words or images need to be removed, simply use the eraser tool to erase. Better than other PDF Reader applications, WinPDFEditor can permanently save the edited PDF content changes in PDF.
Regards,
Regards,
