HCHTech
- Pittsburgh, PA - USA
We have a client (about a dozen employees) that has a NAS they use as a server. So no domain. We created user directories on the NAS for each person, and we redirect the local Desktop & Documents folders there. This gets the most important data centrally located where it can be easily backed up. This has worked surprisingly well in the 3 years we have done their service. They got all new computers last week and we have been installing them this week. I learned a couple of things about redirected folders in the process:
Unfortunately, I didn't learn the solution to the Ninite problem before I ran into the Quickbooks problem, so I wasted a few hours today beating my head against that particular wall. Fun times.
- Ninite installers will not work if your Desktop folder is redirected. Not sure why - the thing downloads to the downloads folder, which is local, and is run from there. They all error out with a "I can't find something" error. If you put the desktop folder back in it's original location, then they all work fine.
- One workstation serves as their Quickbooks server. They have 5 licenses of Quickbooks Desktop Premier 2020. Quickbooks installs and runs correctly, but you cannot share the data folder in Quickbooks Database Server Manager if the Desktop folder is redirected. You get an "Unable to resolve the root folder" error when you try to browse for the data folder to scan. This error unfortunately is not elaborated on in any my Google searches. Again, not sure why this is since the folder being shared is local, and access to that folder works just fine from other computers. Intuit level 2 support also doesn't know about this error. If you put the Desktop folder back in it's default location, you can do the folder scan fine and then multi-user access works as desired. Further....once this is done, you can re-redirect the Desktop folder back to the network location and the sharing still works.
