TechguyUK
- Lincoln, UK
Went to a customer the other day and the machine was totally dead. No fans, No LED's, No beeps. Checked the PSU with a tester and nothing at all so I diagnosed a dead PSU and began the process of replacing it.
Installed the new PSU and powered up, the CPU fan did 1 spin and then stopped. So I disconnect all but the ATX and P4 connectors and the machine then appears to power up ok. I re-installed the drives one by one and found that as soon as the HD is installed, the PSU shuts down a split second after power on.
So with the new PSU, old PSU and hard drive on the bench I plug in the PSU tester again and its clear the old PSU bad. The new PSU checks out fine as long as I dont plug a molex into the hard drive - if I do the new PSU won't power up. So it appears that the HD as failed and taken the PSU out as well.
The customer has said that the machine has been getting gradually worse in terms of powering down on its own and numerous other errors.
Anyone else seen an electrical fault on a drive kill a PSU ?
Is there any chance to recover the data from the HD without going to a professional data recovery company ?
