WindsorComputerRepair
- Canadia
So i'm looking at two solutions right now.
I need a PF Sense router, a 3cx server (Windows only) and a surveillance server.
Initially, I had the 3cx server and the surveillance server running on the same dual core PC in my rack, and a PF sense box separately.
However, I was thinking of building a Xenserver box in a 3U enclosure for my rack that will run my 3CX, Surveillance, and PFSense all in one box, but on three seperate VM's.
Any ideas on whether the virtualized environment will work better than each being on a bearmetal server, and what specs I should aim for?
3CX will handle up to 5 calls simultaneously, (This is my current license limit),
the surveillance server will handle up to 5 security cameras at 720p (Right now 640x480) set to record only on detect
And the pfSense will be hooked up to an *cringe* HP Procurve 48 Port switch, and a separate WAP (Or two for guest networking)
Any suggestions?
Right now I have an old quad core with 5 GB RAM laying around, and I think this will do the trick (Given that the previous hardware was a dual core with 1 GB ram, and an intel atom box)
Any suggestions?
