How to attach phone cord around doorway?
timeshifter
USA
Need to run a telephone line for a corded phone up and over a doorway and around the room to a table. The biggest challenge is getting it up and around the doorway. For purposes of discussion, this is the only way to get there.
Already have a white 100' RJ11 cable. Thought about a wire molding, but that seems overkill. Just need the wire to stick to the door frame. Could use staples or maybe some kind of double-sided tape or even glue.
Thoughts?
I do have a staple gun like that in my garage, haven't used it in years. That might be the answer. Just gotta make sure I don't crush the wire and that I can get it in tight enough around the door frame to look neat and not split the wood.
For single phone cables I find a staple gun by far the neatest. Crushing the cable isn't much of an issue unless you really crush it.
The Tacwise Combi suggested above is actually what BT (UK Telco) engineers use when installing phone lines.
CAT5/6 on the other hand... slight bit of crushing can cause all sorts of issues. If using a gun for those it's recommended to use insulated staples... but they are plain ugly so I usually opt for trunking/conduit.
As an ex-BT engineer, I've done hundreds of these. The cleats @Moltuae suggests are your best bet. Keep the nails on the open side (so, sequence is: nail, cable/clip, wall) and don't nail within six inches either side of a bend/corner. A few gentle taps, not one big hit. If you get resistance, pull out and move the cleat up or down an inch or so. Architraving is usually cheap old wood and full of knots etc. Space cleats at length of tack hammer handle (i.e. about 1 foot/30 cms).
