NYJimbo
- Long Island
Got a HP 2000 here running Win 7. Customer says its dead. He said it was working, turned it off last night, turned it on this morning and now nothing. Of course he didn't do anything to it, no drops, spills, not overheating. Turns out it is working but it has a weird boot issue I haven't seen before.
If you power it up you get the "Press ESC Key for Startup Menu" messages which is where you can do any number of things like esc,f1,f2,f9,10 for various boot up options like any other laptop. That goes away in about 2 seconds and then the laptop just sits there and will not do anything for about 1 minute. Timed its actually 1m5s every time. After that time it will boot normally.
If you decide to hit one of the function keys at boot the system will acknowledge your key press but then go to a blank screen and do nothing for a minute.
It turns out if you hit ENTER any time during that wait period it will go on to do whatever it should have, normal boot, BIOS page, system tests, etc, but you must hit ENTER, no other key will make it respond until the 1 minute timeout is over.
I reset the BIOS to defaults, flashed the BIOS to the latest one. Checked all BIOS boot settings including turning off any network boot options. Still does the same thing.
I disconnected the HD, DVD, keyboard, touchpad, etc just in case it was timing out on some interrupt but still doing it. Ran internal HP system checks, swapped ram with known good. Still same.
The machine works flawlessly except for that weird boot timeout issue. Device drivers show nothing weird like an bad device or missing drivers (I know its failing outside the O/S but maybe DEVICE MANAGER would give a clue).
Anyone see this sort of thing and resolve it ? It's almost like its waiting for a response like you get when it warns you windows isn't clean and it will do a system repair in 30 seconds, except this does it right after the initial start up page and there is nothing on the screen, not even a cursor or any other character.
