HP notebook 15-ay029ca beeps on battery after screen turns off
Galdorf
Ontario, Canada
Have not seen this issue before when power savings kicks in and it blanks the screen 30 secs after it starts beeping 3 beeps stops 20 secs and 3 beeps in a loop what is odd if i move the laptop or just nudge it stops beeping right away.
I have turned off turn off screen after 5 mins in power settings to always on no beeps after 5 mins all drivers have been updated and bios has been flashed to newest version.
OS: Windows 10 1809
The sounds like something is not grounded if your nudging it and it stops, is the laptop power cable one with a small notch on the "O"
If you pull out the battery and attempt sleep mode same issue
You can use in admin mode the shutdown /h command to force hibernate
shutdown /?
Usage: shutdown [/i | /l | /s | /sg | /r | /g | /a | /p | /h | /e | /o] [/hybrid] [/soft] [/fw] [/f]
[/m \\computer][/t xxx][/d [p|u:]xx:yy [/c "comment"]]
No args Display help. This is the same as typing /?.
/? Display help. This is the same as not typing any options.
/i Display the graphical user interface (GUI).
This must be the first option.
/l Log off. This cannot be used with /m or /d options.
/s Shutdown the computer.
/sg Shutdown the computer. On the next boot, if Automatic Restart Sign-On
is enabled, automatically sign in and lock last interactive user.
After sign in, restart any registered applications.
/r Full shutdown and restart the computer.
/g Full shutdown and restart the computer. After the system is rebooted,
if Automatic Restart Sign-On is enabled, automatically sign in and
/a Abort a system shutdown.
This can only be used during the time-out period.
Combine with /fw to clear any pending boots to firmware.
/p Turn off the local computer with no time-out or warning.
Can be used with /d and /f options.
/h Hibernate the local computer.
Can be used with the /f option.
/hybrid Performs a shutdown of the computer and prepares it for fast startup.
Must be used with /s option.
/fw Combine with a shutdown option to cause the next boot to go to the
firmware user interface.
/e Document the reason for an unexpected shutdown of a computer.
/o Go to the advanced boot options menu and restart the computer.
Must be used with /r option.
/m \\computer Specify the target computer.
/t xxx Set the time-out period before shutdown to xxx seconds.
The valid range is 0-315360000 (10 years), with a default of 30.
If the timeout period is greater than 0, the /f parameter is
implied.
/c "comment" Comment on the reason for the restart or shutdown.
Maximum of 512 characters allowed.
/f Force running applications to close without forewarning users.
The /f parameter is implied when a value greater than 0 is
specified for the /t parameter.
/d [p|u:]xx:yy Provide the reason for the restart or shutdown.
p indicates that the restart or shutdown is planned.
u indicates that the reason is user defined.
If neither p nor u is specified the restart or shutdown is
unplanned.
xx is the major reason number (positive integer less than 256).
yy is the minor reason number (positive integer less than 65536).
Ok this is odd but i scanned all drivers for unsigned drivers i found drivers that turn your cell into a modem i removed the drivers now there is no more beeping well that is a first i have not been able to find such a problem on google next time i see this driver scan will be first thing i do.
