DBM Assistenza PC
- Romania
HP Pavilion dv7 Cleaning CPU FAN
Set video speed to 0.25. I hope this can help!
Reminded me of this:
Unfortunately for smokers, its not just the dust that accumulates in the computer, but all of that tar, etc. etc.. The same stuff that shows up in their lungs. I'm speaking from experience - I used to smoke but have no reason to ever want to start again. Smoked from about 1970-ish up until 2005.I tore apart a laptop once that was so dirty that the area between the fan and the heat sink fins look like it had a factory installed filter in it. The dust... filter??? I dont know what to call it, it was at least a quarter inch thick. I saved it to show the customer and told them it was not a good idea to smoke around the computer but I'm sure that went in one ear and out another. I just love how people tell me there's something wrong with the computer, I figure out what it is and tell them what it was and then they ignore me. Its ok I'm the computer tech, I know nothing... I get a bit sarcastic some times. lol
The only time I take one that far apart is if I have to replace something inside the unit. Otherwise I use a straightened out paper clip and insert it into the bottom vent of the computers case (where the fan resides) and then using compressed air, I blow thru the air outlets toward the fan to rid the unit of the crap which has accumulated inside. When I do take a unit apart to do any internal work I will also do the aforementioned cleaning including the heat sink pads and the areas on the PCB where they come in contact.
Generally when I am pulling apart a unit like this it usually means that it is being stripped for good parts and the rest is going into the scrap bin.
Sometimes it is still a good idea to pull the unit apart to clean the heat sink / CPU and re-apply heat transfer grease. I did that with a Latitude E5410(?) just this past Friday and it made a HUGE difference in the cooling of said unit. It's all loaded and already on the sales floor.Years ago I stumbled upon the same idea but with a shop vac. I use a non-conducting toothpick held at an angle to prevent the fan from over-speeding while the 2" vacuum hose fits flatly on the laptop case and pulls out all the dust and debris that builds up between the heat sink and fans exhaust port.
The first few times I pulled the laptop apart to ensure this methodology worked. What a time saver.
