Hi All.
Interesting problem here.
I just setup a new HP ML350 Gen10 server for a client. Loaded Server 2016 Standard as a Hyper-V Hypervisor and installed the HP SPP to get the latest drivers etc, then provisioned a single VM running another instance of Server 2016 Standard to be his DC and file server. Very small accountant client. I set static IPs for the Hypervisor and the VM and made the DC the DHCP and DNS server etc.
All worked fine in my office when setting it all up, connected to an Untangle router initially, and then when I needed to setup the DHCP settings on the VM, and they were in a different range than the Untangle, I connected a temporary Zyxel router I had lying around and used that as the gateway to get everything setup and all went well.
Next day I deliver it to the client who's using a MikroTik router provided a company doing his web filtering. This company manages the router (connected to a cable modem provided by the ISP) and only allows a white-list of certain sites to be accessed, and all the computers on the network need to have Internet Explorer Proxy settings configured to go through this company's proxy in order to get online.
The basic network is setup very simple: ISP modem > Mikrotik router 4 ports connected to the 4 jacks in the wall that go around the 2-room office. The jack in the office is connected to a dumb Netgear Prosafe gigabit switch which connects the computers, printer and phones in that room. When I tried to connect the new server to the Netgear switch it would not recognize the cable connection. No lights on the switch nor the server NIC ports. Tried different ports on the switch, different cables, and also tried all 4 server ports. All dark. If I connected the iLO port, it DID light up and get a connection.
I tried connecting the server directly to the wall jack which is going to the Mikrotik, bypassing the switch, but it still didn't light up. I went into the BIOS settings and it said that there was no connection, tried all the ports, refreshing the status in between, with no change.
Now if I took the Mikrotik out of the equation, and connected this wall jack directly to the cable modem, the light on the server NIC lit up immediately and I was able to get online from the Hypervisor once I changed the NIC settings away from a static IP. When I put them Mikrotik back in, same thing happened: no lights and no connection.
I spoke to the filtering company and they didn't know what to make of this. They were thinking maybe it was running an older firmware or something, so they sent the client a newer router which was installed today but still nothing doing.
So to break this down: Everything else except for this server works fine on this network with this equipment. Is it because the proxy isn't configured? If so, shouldn't the link light come on at least and the server should recognize a cable being connected?
If it's the router, maybe an issue with port speed and duplex settings, then why would the switch not light up when I connected the server to it?
Any ideas? I'm stumped.
