autumn
- Geelong, Victoria, Australia
G day all
I'm at a bit of a loss with this. The server is working and the issue is left with the software guy now but I have questions.
I've installed a new server Hardware for a customer with Server 2022 Std and setup Hyper V. We have had several hard drives fail in the old server with has Server 2012 Std and Hyper V.
So shut the VM server down.
Move the VM drives to the new server, on errors on moving,
the VM itself wouldn't export so made a new VM and attached the VM drives in the same configuration as the original.
Start the VM up on the new hardware.
Windows Server has started fine and all the system looks fine
contacted the software support for them to test
They said everything looked ok
However this morning the customer said one part of their LOB software isn't working. Software support will fix it tonight.
So my question is
Shouldn't the VM server be seen as the same so why would their LOB software have an issue? Customer says their are always little glitches when anything is done with the server. How can a database be so touchy with basically a shutdown and restart?
Is there anything I should watch for when moving VM's? I have done a number of them without issues and I understand that this will be more due to the DB.
So my question is
