Big Jim
- Derbyshire, UK
iMac 2010 i3 4gb ram, HDD
Issue couldn't see much of the screen due to graphics artifacts.
Replaced the GPU like for like with a used one.
New card works fine, but now the CPU fan spins at full speed after a couple of minutes.
Using a temperature monitoring program all temps look well within limits, and we are able to slow fan down either manually or by telling the program to link the fan speed to the CPU temp.
Apple hardware test throws up an error
aht 4sns/1/c00000008: ts2p- - 124
a little bit of digging leads me to believe that 4SNS means a sensor fault and the "c" denotes its a cpu sensor, however all of those sensors are correctly reporting temperatures, unless a faulty sensor doesn't show in the software at all, which sensors should I be seeing if that is the case ?
