britechguy
- Staunton, VA
Well, the Lenovo ThinkPad X260 I had written about the other day has turned in to one of those, "I've never seen anything like this!!," experiences from several angles.
First was the failure mode of Windows 10 previously documented in my earlier topic.
The second of which was finding out that whoever originally set this machine up had the Windows OS drive partitioned MBR. The machine was purchased, new, in Thailand, and is not all that old. Whoever set it up partitioned the drive such that the user data was being stored on one logical drive/partition and Windows 10 was in its own. That turned out to be very handy as far as preserving the user data this time around, though I copied it off before starting anyway, as I had anticipated undoing this arrangement.
Well, if you create Windows 10 installation media using Rufus, and make the reasonable presumption that any newer machine that started out life with Win 10 will be partitioned GPT, but it's been partitioned MBR, you run into the situation where your install media is, for all practical intents and purposes, trash.
After re-creating the Win10 install media for MBR, the install went OK, but:
1. I was never presented with any option to reinitialize the whole HDD and start from scratch.
2. I could not SHIFT+F10 out to command prompt/Power Shell to run diskpart no matter what I did.
Windows 10 did reinstall on the logical drive/partition it had been on before, and successfully. This was, however, a completely clean reinstall experience unlike any other I've had over the last 5 years.
Now, when you have a machine that won't boot into Windows 10 as I did when this all started, is there some easy way to determine how the OS drive is partitioned? I would still expect GPT as the default, but it would be really handy to have a method to determine this definitively.
