thecomputerguy
Client contacted me because "After I left his house" (Which was to install an Ubiquiti AP to get his Ring doorbell to work), he emailed me and said ever since I left his house his email which is at a .com he owns and he uses via a POP connection cannot send email to his Wife which is at an AOL.com email and here is the bounce back he gets ...
Thoughts?
The original message was received at Fri, 2 Feb 2018 18:40:57 -0500 from
[10.30.71.207]
*** ATTENTION ***
This email is being returned to you because the remote server would not or
could not accept the message. The registeredsite servers are just reporting
to you what happened and are not the source of the problem.
The address which was undeliverable is in the section labeled:
"----- The following addresses had permanent fatal errors -----".
The reason your mail is being returned to you is in the section labeled:
"----- Transcript of Session Follows -----".
This section describes the specific reason your e-mail could not be
delivered.
Please direct further questions regarding this message to your e-mail
administrator.
--Registeredsite Postmaster
<xxx@aol.com>
(reason: 521 5.2.1 : (CON:B1)
https://postmaster.aol.com/error-codes#554conb1)
----- Transcript of session follows ----- ... while talking to
mailin-01.mx.aol.com.:
>>> DATA
<<< 521 5.2.1 : (CON:B1) https://postmaster.aol.com/error-codes#554conb1
554 5.5.0 Remote protocol error
Final-Recipient: RFC822; xxx@aol.com
Action: failed
Status: 5.0.0
Remote-MTA: DNS; mailin-01.mx.aol.com
Diagnostic-Code: SMTP; 521 5.2.1 : (CON:B1) https://postmaster.aol.com/error-codes#554conb1
Last-Attempt-Date: Fri, 2 Feb 2018 18:40:59 -0500
Thoughts?
