occsean
- Oregon City, OR
Morning everyone...
I have a veterinary practice I am currently working with that is suffering intermittent and maddening performance issues when using their practice management software (Avimark). Spcifically, having a task as simple as opening a chart taking 30-45 seconds at a time. Or moving between modules or screens in the software. Basic stuff that should and used to be much faster. I know speed is a matter of perception but customer says this has been occurring for over 8 months.
They initially called me in a few months ago as their current tech had not been able to solve the issue over the course of 8 months and they wanted a fresh set of eyes. I identified one of the major culprits being an 8 year old AMD FX desktop hackjob of a machine acting as their "server" for the Avimark software and database and recommended it be replaced with a proper server as suggested by manufacturer.
They purchased a server direct from the software company. Xeon E3-1225v6, 32GB ECC, 4X1TB SAS HDD in RAID 10 on a MegaRAID SAS 9361-4i card. So the machine is most definitely a million times better than the previous junk. It's essentially being used as a file server, hosting AD, DNS, and DHCP.
Here's the problem....They are still experiencing the same issues as before. The server needed to be replaced regardless and while I didn't expect it to be a one size fits everything solution I did expect to see vast improvement if not near nirvana. That's on me for being tunnel visioned.
In any event, I'm trying to determine the most effective way to completely isolate and resolve the issues and not leave any stone unturned. My ideas so far are:
1) Their ancient SonicWall has already been pulled. Unfortunately they stuck an 8 year old Firewall VPN from Netgear in it's place with a static address that I'm not even sure is theirs and hard coded DNS from Comcast. DHCP is handled by the server. I want to swap that out in order to troubleshoot further
2) I'm going to bring in a certified low level contractor to test and certify every cable that is in the wall as well as double check jacks. There is no patch panel and if warranted I will advise getting one. Currently a hodgepodge of small unmanaged gigabit switches.
3) Most of the workstation machines are C2D or 1st and 2nd gen Core CPU's with 4GB of RAM. No GPO's are being pushed and all users utilize the same login and have local admin rights. I've advised replacing and locking machines down, so far fallen on deaf ears. I've proposed bringing in a box that just has OS and LOB app and testing performance on it as compared to existing machines
4) I've installed Spiceworks Network Monitor on the server and am gathering data to analyze as well
What other steps can I take to isolate and solve these performance issues? Accoprding to the customer they tend to be site wide when they happen (16 workstations) so where I suspected the server before I am really leaning towards the network infrastructure as the cause but I want to be able to make my case with evidence prior to advising any drastic steps be taken.
Appreciate any and all insight from you all
Thanks
Thanks
