not trying rig anything just wondering if there is a way you can reconnect the ribbon to the clip or a new clip or is the only option to buy new keyboard?
I have a line item in QuickBooks called "Repair University Tuition" and I would then charge this unfortunate incident to that.
Not to take away from the OP here but since it is similar why not ask this...does anyone have a good source for a Compaq CQ50-115NR power switch? Problem is it is attached via a small ribbon which it would appear was glued into place as there are no exposed wiring and it was the smallest bit of tacky where the ribbon was attached. If you notice the was, (I'n sure you did ) you know the problem is it fell off, was lose and the wifi wasn't working every press and now not at all...parents lappy the dropped, did work and all in system is fine but that ribbon, looks like this but the other side where it attaches appears to have no option to re-attach sadly. Thanks to anyone with some leads on this!
Here you can see the cable and the switch and what I refer to, don't seem to be an option to attach it though...
I would try to fix it yourself, otherwise......
http://cgi.ebay.com/HP-G50-G60-CQ50...emQQptZLH_DefaultDomain_0?hash=item20aef17d3b
I wish fixing was an option...the cable has nothing exposed, I see no way to attach it to the solder joints, fairly poor design that's for sure, really do not want to have to purchase a replacement for $60 bucks though!
But anyways, thanks buddy!
this video has some idea of how to do it.
http://www.youtube.com/watch?v=zQ-ySzofaGI
What you need to do is to sand the ribbon on the bottom to expose wires. This will have the effect of exposing and stripping the wires. The exposed bare wire should encourage the solder to flow to them. Soldering paste may be a better idea with a hot air station though.
