I need some help from the Apple technicians out there.
My main laptop is a MacBook Pro 15" 2.2GHz, with 2GB of RAM. Lately, well not exactly, I am having problems with distorted display... that is quite a popular problem with MBPs.
Not knowing much about this myself, as I usually repair IBM machines, I've searched about the problem and found out about the Apple replacement due to faulty NVIDIA GPUs out there. Took the MBP to our local Apple authorized center to find out that mine does not qualify for the free replacement. Considering it doesn't happen often (unless the system is stressed out / sometimes even if not), I decided to pay the fee and move on without replacing the logic board; since it would cost a fortune. I would also be able to get it cheaper and replace it myself ONLY IF I'm sure it's the logic board and not something else.
Today it happened randomly again, just switched the MBP on this morning and got the distorted display (full of vertical lines that makes it difficult to read text, sometimes it also turns yellow, purple and some random colours). What I have decided to try now was to connect an external monitor, a 24" display, to find out that it turns out crystal clear BUT NOT the MBP display.
After around 5 minutes using the external display the MBP display returned to normal. Now, since the external display was fine, I am wondering that it is not actually related to the GPU (thus the logic board), but to the monitor (connection or something else), or any other part.
From your experience with MACs, what do you suggest about this issue?
Thank you guys
Thank you guys
