frenchscottie
- Scotland
A customer brought in the above mentioned MacBook Pro with no display.
Done tons of laptops and pc's etc. but only 3 or 4 Macs and I don't like turning away a customer. When you turn it on you get a slight flicker of light and it plays the startup sound and if you shine a torch through the logo on the back you can see the apple logo is on the screen, but that's as far as it goes.
I've tried resetting the SMC and PRAM, but still the same.
I have tried an external monitor connected to the display port - via an adaptor - to a DVI monitor, but nothing. I don't see what fn and F key to press
to switch output the only ones I can see it could be are F3 with 3 squares on it of different sizes, (I assume this is the key) and F4 with 6 small squares on it.
I've checked the screen cable and seem ok.
Is there anything else I should be trying before I declare a bad motherboard or could it just be the LED backlight on screen faulty?
oops title should say no display on screen (why can't the title be edited?)
