Vicenarian
Hi again,
I've got a Konica Minolta Bizhub C203 that was set up by a printer technician a week or so ago; anyway, it's got a static IP on the local network and is connected through an ethernet cable directly to a LAN port on the Linksys router. I can access the printer's web page via the network by browsing to its IP address with no issues, and it responds to pings fine.
So, I set up two Windows 7 machines by installing the drivers on the Konica website, with no issues. Both print fine. However, I've got 2 Macbooks (both running 10.8.x) that won't print. I downloaded/installed the appropriate 10.8 driver on the Konica website (same page as the Windows drivers actually), but after installation, when I go to print, nothing prints.
I've also tried adding the printer manually in OSX but clicking on the '+' button in the printers window (in System Preferences), and then specifying the printer's IP address, LPR protocol, and as per the advice of Konica tech-support, putting the word 'print' in the "Print Queue" box.
But neither of the Macbooks will print.
Anything else I should try?
Edit: I should also mention, when I try to print from the Macbook, the print goes to the print queue dialog box, and then disappears, but nothing actually prints.
Edit 2: I also tried using the "General Postscript Driver" that was included on the Mac computers; didn't work
