[BUG] Malware SystemConfigInfo000 and node.exe
Audrey
Alabama
I've been battling this malware all day. It is a typical popup that has "Windows has been blocked" and "Call this number" but it has a delayed cmd prompt that runs from the program data folder mentioned above. Then it pops up in the browser. (node.js serverside java script, c:/programdata/systemconfiginfo000/node.exe)
If I delete the folder it reinstalls. I cannot find it in autoruns, processexplorer, etc. All the malware scanners (malwarebytes, hitmanpro, microsoftscanner, etc.) breeze right by it without a flag, however - when they scan by it - it activates and pops up again.
Anyone else dealt with this one? I have found a few obscure, unhelpful posts on the web...
msconfig uncheck all startups and services not related to microsoft also check for recent software some adobe bootlegs will do that if your able to (without a internet connection) create a new user account and give it admin rights check to see if it's still there as a issue.
HP site mentions this issue but on Windows 7 edition.
Thanks guys! Followed through on both of your suggestions. Finally found several js script files and deleted them, then was able to delete the folder. First time I've had a pop up scam this difficult to remove. Including an image of all the files and folders just in case anyone else needs the info.
I should of mentioned that a boot CD that can give you access to the ntfs would of probably help you way better in resolving this issue.
Also searching by date pattern afterwards will give you a more global view of what was tampered with.
You’re right. A close look at dates and a deeper look at the properties in process explorer got me on the right path. I’m not sure I could see the js files earlier in the day. I did a lot of different things and finally just found them. This computer belongs to the Sheriff’s office so I had to be careful and not interfere with their programs and workflow. I’m going to watch it until Monday and make sure I found everything.
Whew!!
This one was definitely NOT browser based. That’s why it was such a difficult one to find. Usually only takes a few minutes to get rid of those. I’m expecting more calls on this one. It isn’t anything I could’ve talked them through on the phone.
