I'm 95% sure [from the research i've done] my current (main) system is suffering from a failing/bad capacitor, and my mb is like $300, so i'd prefer to save money, and learn at the same time... So, i have a few questions/statements:
1. How do i know the type of capacitor's i need? (https://www.jameco.com/shop/keyword=Buy-Electrolytic-Capacitors) Looks like a decent site to use, but my capacitor would need to be fairly heavy duty correct? as decent power draw, decent overclocks, etc etc. [I'll put my build as an end note] and i'd prefer not to have to replace a capacitor in the future. [I plan on doing more research of course, to learn What uF means, and to see how much voltage they would be...but i figured i'd go ahead and post this as you all are a lot smarter then I, and a lot more experienced, So the odd's of this being a "everyday thing" to you all is higher, which in turn means me asking now gives me time before the capacitor fully dies/etc]
2. Yes, i know it's risky/etc
3. Yes, i know it will still be semi-expensive as i'll probably buy a decent soldering iron, decent capacitors, a cheap test PSU, a PSU jumper, and maybe a cheap CPU, as i hear if i do it wrong, it could ruin other things, and i don't want my good CPU in it, if worse comes to worse. [As i don't think i can test the MB without a CPU, effectively ]
4. My Specs/system:
Cpu - i5-4690k @ 4.2
GPU - Gtx 970 @ +150 / +200
PSU - Silverstone - Strider Gold S 750 W
Mb - Sabertooth Z87
Ram - Corsair - Vengeance Pro 16 GB (2 x 8 GB) DDR3-1866 Memory
misc - MB says Capacitors are:
"The ASUS SABERTOOTH Z87 uses high-end solid Japanese electrolytic capacitors, from Nichicon, on its voltage regulator circuit (a.k.a. “10K Black Metallic Capacitors”). According to ASUS, these capacitors have a lifespan five times longer than regular Japanese solid capacitors, and have a higher temperature tolerance (between -55° C and +105° C, making them military-grade components). This allows you to use liquid nitrogen on your CPU without damaging the capacitors.
All coils used on this motherboard are ferrite-core models."
AND
"TUF Components
Certified for tough duty
TUF 10K black metallic capacitors and MOSFETs are screened by seven rigorous military-grade tests to ensure superior lifespan even under the most demanding conditions. "
4. My Specs/system:
Mb - Sabertooth Z87
AND
"TUF Components
