SmithFamilyDesigns
- Phoenix
Alright, quick comp specs:
MSI CR600 (Hate these things)
C2D t4400, 4Gb pc6400, 320 WD blue label, GeForce 8200M G
Originally came in because it would not power on; no post, no backlight power, the power LED lit and that was it. After EXTENSIVE tinkering, I have now got the computer to turn on. Problem now is that it will randomly shut off. No warning, no nothing, just off.
What I have done so far:
To get the computer powering back on, I had to change the CPU (old one showed serious signs of heat damage), replace the fan and clean the vents. It was running Vista HP x86 SP2 and would do the random shut downs with no warning. Running PC Wizard showed all temps in normal range (100F - 125F) for CPU & GPU.
Whenever I try to boot the computer to QTP for hardware testing, it will always shut itself off somewhere different in the test. I have replaced both ram sticks (also trying 1 stick in different slots), changed the hard drive, tried yet ANOTHER processor, disconnected wifi, USB ports, webcam, and hard drive and it will still always reboot during a HW test. I have also done all of this with different combos of battery/uni power adaptor/factory power adaptor.
For S&G's, I put in a new HDD, installed Win7x64 and it showed the same temps as vista did (few degrees difference) but still shuts down with no warning.
My question to you TN, is it the motherboard? The only thing that I think I haven't tried (depending on posts here) is the actual power switch board, but to buy one is too much for testing and this one seems fine. Anything else I should try or should I toss this in the heap for spare parts/scrap?
Edit: Forgot, I did download the newest bios and flashed that. In the process, after a reboot, I shut down and reset the bios (battery out, cmos battery out, unplugged, hold down power button for 30 seconds) and that didn't make a bit of difference.
