Hello,
So far i've only used cheap network cable testers (under 10 USD) but I am in need of some better gear. These are the features I would be looking for, not sure if all is possible.
Much needed features
- POE-protection, the tool should not break in case I plug in a POE wire in it
- Broken wire, possibility from one end to locate how far in the cable it is broken
- Being able to identify where a wire goes with sound, using a probe.
- Being able to identify which end of a cable is broken, for example if you use a cheap network tool it will only show light that for example "5" is not working, but you don't know in which side of the cable
Not so needed but would be nice to have
- Being able to test actual network speed on a cable without using computer etc (with tester only)
- Being able to see how long a cable runs
- Be able to test TV-signals
If possible I would appreciate eBay links as I find it easy to buy things from there.
