britechguy
- Staunton, VA
This is an issue I have never encountered before, and never encountered anything like it before, so I thought I'd ask if the symptoms are familiar to others.
The machine under discussion is the Dell Optiplex 3010 in which I replaced the PSA last week. This went perfectly, the machine booted back up just fine, and the client has been using it at home for days now. It was running Windows 10, Version 1903.
He says that last night he got a Windows Update notice that he needed to restart, so he did. The machine appears to have been doing for him what I will soon describe, but he did mention, "So I turned it off." I doubt this could have been a firmware flash gone wrong just based on what I could find today.
The Dell splash screen always shows.
When that closes, a black screen with the following text appears (and I may have missed some):
Intel Base-Code PXE-2.1 (Build 083)
Realtek PCIe GBP Family Controller v2.58 10/08/13
DHCP: (Twirling pipe character that eventually stops, after which the Client MAC Address & GUID are presented)
PXE-E53 No boot filename received
PXE-MOF Exiting PXE ROM
No boot device found
I ran Dell's On-Board Diagnostics and everything except Hard Drive passes, and for Hard Drive it presents:
Msg: Hard Drive - No Hard Drive detected or disk controller not supported.
I've already unseated and reseated all cables, power and SATA, to the HDD and Mobo.
The obvious suspicion is that I have had a HDD failure, but this seems to be too obvious, not to mention a bit to coincidental for my liking. So I thought I'd ask if this sort of situation rings a bell for anyone, particularly with regard to the obvious fault possibly being reported spuriously.
I have not, as yet, pulled the HDD and connected it as an external drive to another machine to check its state when doing so.
If there are any specific further diagnostics I should be doing/checking, that would be good to know, too.
Thanks in advance for any and all assistance offered.
