phaZed
- Richmond, VA
So, I'm wondering if others have experienced the same type of issues as I have.
I am increasingly seeing bad Optane drives in where Windows constantly corrupts itself - sometimes to the point of not booting, but also to the point where strange issues occur, but still boots. My latest customer that has a 2 year old AIO with an Optane drive... the thing corrupts something new almost every time it boots... it does boot. browser.dll... gone, and can't replace it, it just *disappears*. Windows updates fails with "windows update error 0x800703f1".
Running ckdsk c: /f will *fix* the drive, only to have it seemingly reverted immediately, I can run chkdsk 10 times and it will always seemingly fix the same problem but never resolve.
I can't install drivers via Windows update or SDIO - the install fails when letting the Windows update process manage it. I can go into Dev manager and manually search online, then it will install, but it won't install everything.. ie. The mouse fails to install, the keyboard fails to install.. have to manually install the driver via dev manager. Another example.. My Zalman drive, I have to manually install the HDD driver, then the volume driver, then the VCD driver... after rebooting... it's all gone again, like I never did anything.
If I edit the registry, on next boot, it's back to where it was.
So, it's not an isolated incident for me.. this is the second or third time for this exact type of wonky behavior. Other behaviors include totally borked hard drives - it's gone RAW but the hard drive passes SMART and tests. Sometimes there is inconsistencies between the Optane drive and the HDD.. as in, the Optane drive has the file.. but it NEVER goes/updates to the HDD. Boot issues, no-boot issues, etc.
Remove the Optane, reinstall, everything works fine. With Optane.. everything falls apart. Is this stuff absolute garbage or what?? I've got like 10 of these 16GB drives piled up in which removing them fixed the issue. Thoughts?
