mmanna
- Englewood, FL
Hi, I've encountered a really strange issue w/ NTBackup and would appreciate any help or insight that anyone can offer. I've spent days Googling and trying different things but can't seem to find a solution!
Computer is an HP Proliant M3 server w/ Win 2003 SBS Server w/ SP2.
I am trying to use NTBackup to backup over the network to a WD MyBookWorld 1TB (which supports gigabit networking). I also installed a Cisco 8 Port Gigabit network switch and verified that the server's NIC supports and is running at Gigabit speed.
I've been doing all of my troubleshooting remotely, so everything that I describe below has been done via a terminal services session.
If I open ntbackup and use the backup wizard to manually run a full backup to the backup drive via its UNC path, it works great (resulting in a 50gb backup file). I read somewhere that backup via a UNC path is better than via a mapped network drive.
When I schedule an identical full backup via the same UNC path, it will not complete. The task is being scheduled to run as Administrator. The ntbackup log reports things such as:
Error: The device reported an error on a request to write data to media.
Error reported: Unknown error.
There may be a hardware or media problem.
Please check the system event log for relevant failures.
and
Error: C: is not a valid drive, or you do not have access.
Also, the event log shows:
5:00:00pm ntbackup "Begin Operation"
5:01:14pm ESENT "wins (2944) Shadow Copy 13 freeze started"
5:01:17pm ESENT "wins (2944) Shadow Copy 13 freeze stopped"
5:03:44pm ntbackup "Begin Backup of C:"
5:18:23pm ntbackup "End Backup of C: Warnings or errors were encountered"
5:18:24pm ntbackup "End Backup of C: Warnings or errors were encountered"
5:18:26pm ntbackup "End Operation: Warnings or errors were encountered"
5:18:28pm UserEnv "Windows cannot unload your classes registry file - it is still in use by other applications or services"
The resulting file size from the failed backup always seems to be in the ballpark of 1.3gb.
When schedule an incremental backup to run, it completes without errors (and is typically 3 to 4gb).
After many hours of googling, I've tried several things:
- Changed from a mapped network drive to a UNC path (made no difference)
- Added "Administrator" to the "Backup Operators" group. (made no difference).
- Disabled "Shadow Copies" for drives C & D (via the drive properties' "Shadow Copies" tab.)
- Verified that the server has latest service pack (SP2)
- Reviewed various MS KB's, none of which seem relevant.
I am really stumped here as things just don't seem to add up.
What's different between running backup manually and via scheduled task? Either way, the task is being run as Administrator.
Based on the fact that backup completes manually without a problem, I do not believe this is a network issue or a problem with the destination drive. However, the scheduled Incremental backups complete without error and have been scheduled the same way as the Full backups, so what gives?
I appreciate any suggestions or help you may have. I've attached a sample NTBackup Log file.
Thanks,
Marc
and
Thanks,
Marc
