HCHTech
- Pittsburgh, PA - USA
I'm setting up an RDS server for a client who is hiring about 7 remote employees. All will be connecting through VPN, so no RD Gateway is needed (as I undersand). I spun up a fresh Server 22 VM, joined it to the domain, added Remote Desktop services, and did a "QuickSessionCollection" which is meant for exactly this "all on one server" situation. Single server has Connection Broker, Session Host, Licensing and Web Access roles. The licensing is set "Per User".
Everything works as expected - I have installed their LOB apps and did a shared activation installation of Office (all employees have Business Premium licenses). We purchased 10 RDP CALs and they have been loaded into the Licensing Manager, which shows the server as Activated.
I've run into two problems, which may be related. When there is an active user session, it does NOT show in Server Manager in the Connections section. Also, if I try to connect with a 3rd user account when there are already 2 active sessions, there is a popup asking which current connection you want to disconnect.
In the event log, I'm seeing an error 5719, source = NETLOGON: This computer was not able to set up a secure session with a domain controller in domain XXXXXXXX due to the following: We can't sign you in with this credential because your domain isn't available. Make sure your device is connected to your organization's network and try again. If you previously signed in on this device with another credential, you can sign in with that credential.
The computer is clearly joined to the domain, I see it in AD, and can browse the network unfettered.
I'm also seeing error 1306 - Remote Desktop Connection Broker Client failed to redirect the user XXXXXXX\Username.
I found this post googling, which states you can use group policy to increase the allowable session count, and I've followed those instructions but the problems remain. I'm not sure how to troubleshoot this further. There were no errors or problems with the initial deployment, and things are working except for the session limitation.
What should be my next step?
