Redirected Folders to a NAS turning into .tmp files
tek9
NJ
Hi all.
I just onboarded a new client the other day. Around 10 computers or so running Windows 7 (not sure if Home or Pro. didn't do a full walkthrough yet.), no Server at this time. They used to have a Windows 2003 Server a few years ago, but their previous tech moved them off it and onto a 5 bay Synology to server as their file server. Their Documents folders are redirected to the NAS and they work off it, as far as I can see. The computers that I looked at had the MS Sync Center enabled and running.
All the users are experiencing the same issue when they use Word or Excel etc. Namely, they have a few files that they change constantly, for example an Excel sheet. They come in the morning, the sheet is present in their Docs folder, they open it, make their changes, save it and close it. They can come back to 5 minutes later or so to reopen the file but it's gone. In its place is a randomly named .TMP file with the timestamp and size of the original file. If they change the file extension to xls or xlsx, they can open the file normally and it will contain the recent changes made.
Now I'm aware that when they open the file housed on the NAS, it'll download a tmp copy to their computer, and that's the file they're working on. Question is, why after saving changes, is the original filename disappearing and the tmp file taking it's place? I'm figuring it has something to do with the Sync Center, but not really sure where to go from here. Is there a setting I can tweak to prevent this?
All these users are working in the same office. There are no mobile users that should need the Sync Center, if I understand correctly.
(note I don't have much Windows Server experience, so this may sound simple to you but not to me.)
Thanks for the help.
Why are they using Sync Center? Personally I'd only use the if the other endpoint is a M$ OS box. Why not implement Synology Cloud Station Drive?
https://www.synology.com/en-us/knowledgebase/DSM/help/CloudStation/cloudstation
They do have it installed and I noticed the client app running on 2 of their computers, but I'm not sure if it's working correctly.
What I would like to know is if I need the Sync Center or Cloud Station at all. Can't they just have the files residing on the Synology without syncing a local copy to their computer? It's probably better for performance reasons, but I'm wondering if it's causing this issue.
BTW: one thing I forgot to mention is that the Synology recycle bin is enabled. When I checked it I saw that it had the original filename in the recycle bin at the time the edits were made. As if someone deleted the file after the change was made, and saved the tmp file in its place.
Sync Center is doing the two copy thing. As you mentioned just setting up a network share point and mapping the drive makes sense. Unless they have laptops which go in and out. In that case the Cloud Station makes sense. For my customers I set them up with shares for local, VPN for remote, and iDrive for backups.
OK, thanks for confirming my suspicion. I'll disable the Sync Center stuff and see what happens.
TYVM
